03-20-2022, 10:06 AM
#21
frig storage
when I winterize, I always put crumpled newspaper in the fridge to help eliminate mold and mildew. Seems to be effective.
Buck Gilpin
Sterling PA
illegitimi non carborundum
always be sincere even if you don't mean it
03-20-2022, 11:24 AM
#22
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
03-20-2022, 11:32 AM
#23
Originally Posted by NevadaMiniLite
My Mini Lite (and my Lance before that) have a master disconnect switch - both located under the cross piece of the A frame on the tongue. Flip the big red handle, and all battery power to the trailer is cut off.
So you changed terminology from Master Power Switch to master disconnect switch. "Power" is general - can refer to any type of power including 120vAC as I wrote; master disconnect switch implies battery - as in 12vDC.
03-24-2022, 06:49 PM
#24
Originally Posted by bikendan
Actually that isn't necessarily true either. I would guess that the majority of FR TTs, don't have a factory battery disconnect switch.
For example:
Rockwood/Flagstaff, yes.
Salem/Wildwood, no.
Cherokee, mostly no.
And a lot of the ones that do have them, still provide power to certain things, even in disconnect mode.
FWIW, our Salem Cruise Lite does have a factory battery disconnect switch.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
03-24-2022, 06:56 PM
#25
Interesting. Is it the A-frame mounted red key type or a rotating knob type or a push-pull type?
03-25-2022, 03:46 AM
#26
Originally Posted by {Tpc}
Fwiw, my Salem has a factory battery disconnect switch and it does shut off our fridge. It also shuts off power to the control panel (tank sensors) and water pump, but I believe the slide still works as well as the tongue jack. I’m not 100% sure about the lighting In the trailer when off, but I feel like a couple of lights still work while most don’t.
If it didn’t shut off the fridge I’m not sure what I would do as there isn’t a on/off switch on the 12v everchill. I’m unsure if hitting the breaker would turn it off because I think those are 120vac circuits but I could be wrong.
If it is 12 volt you could always just pull the fuse in the panel. Crude but effective.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-25-2022, 03:56 AM
#27
We use a device to keep the doors open so air can circulate and prevent mold. VERY important when y9ou live in the Humid South
https://www.campingworld.com/no-mold...B&gclsrc=aw.ds
03-25-2022, 04:52 AM
#28
Our 2020 Wolf Pup 16FQ has a battery disconnect switch mounted to the lower left of the fridge inside that shuts down ALL power when not connected to shore power.
03-25-2022, 07:08 AM
#29
Pseudonym
I installed a battery disconnect for $10 and 10 minutes of my time.
2021 Shasta 18FQ
2023 Ram 1500 4X4 Lone Star Crew Cab 5.7L HEMI eTorque
Attachment 251949
