Originally Posted by TimVWulp
Are you plugged in to 30 or 50 amp power? Second ac may not work on 30 amp service if your unit has a power management system. I have 3 ac on my unit and power management system let's 1 ac operate on 30 amp power.
OP Stated he has TWO ac units a 50 amp Service and plugged into a 50 amp outlet.
His Load center will have the rear AC one side and the front on the other side.
I do not believe anything is overloaded. A bad start condenser on the front one, a stuck motor (Mud Daubers come to mind) could be the problem.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
