Old 06-15-2020, 10:31 PM   #1
Furnace
2018 Coachmen Freedom Express
When I turn Furnce on with the thermostat it starts and shut-off 30 seconds after, only cool air comes out. Fuse is good, also have 13V on Battery
Dometic DFSD20121
RDamps is offline   Reply With Quote
Old 06-16-2020, 04:18 AM   #2
Member: Old Man Club
RockDodger's Avatar
I am going to ask you a question that may spark your ire, but it needs to be asked. Is your propane tank turned on? (Kind of important)
"Walk softly...and carry a lot of tools!"
2016 Ford F250 Super Duty Crew Cab, 4x4
2021 Palomino Puma 27RLSS
RockDodger is offline   Reply With Quote
Old 06-16-2020, 05:53 AM   #3
Are you hearing the ignitor? Is the exhaust plugged? I know I always bleed the air out of the line by lighting one of the burners on the stove first.
KKonyha is offline   Reply With Quote
Old 06-16-2020, 06:39 AM   #4
Hey
Propane on , also turned on stove and let it burn for a little bit, I don't hear any kind of spark at all just fan.
Old 06-16-2020, 08:08 AM   #5
It sounds like the DSI is not working. I will have to research to see the causes.
Old 06-19-2020, 06:21 AM   #6
Hey
Changed sail switch and elotrode
Same issue
furnace
