Old 11-06-2018, 06:13 AM   #1
furnace and not heat pump??...
Howdy....new to this forum, so welcome all.....my question is, i bopught a 2018 legacy 34A, and was wandering if theres a way to run just the furnace , and not the front heat pump??.....thanks all
colton7711 is offline   Reply With Quote
Old 11-06-2018, 06:28 AM   #2
fonzie's Avatar
If you have a Dometic thermostat, put it on "Auto" and that should fix your issue....see page 5 in manual....
File Type: pdf Dometic Thermostat- Single Zone Digital.pdf (1.40 MB, 29 views)
Fonzie
Nights Camped:2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42) 2019(28)
Old 11-06-2018, 09:15 AM   #3
Head Rambler
We really need to know which HVAC mfg. you have and which thermostat you have.
In case you do have the Dometic thermostat mentioned above, as said, you set the FAN to AU and then select Furnace mode, and just the furnace will run.
Gotta go campin!
Old 11-06-2018, 09:20 AM   #4
i have the wall mounted touchscreen control panel....not sure of the name of it...not the old domestic ones that i had in the 5th wheel....i know on them you have to be in auto....
Old 11-06-2018, 09:42 AM   #5
is it multi zoned . if so one zzone will have the electric heat pump and the other will have the gas [furnace only]
MR.M is offline   Reply With Quote
Old 11-06-2018, 10:52 AM   #6
2 zones...bedroom is only cool and off.....living room is heat cool and off...and when you turn on the heat, it says "heat pump+ furnance" and they both run...was hooping a way to just turn on furnace......
Old 11-06-2018, 12:33 PM   #7
Head Rambler
If you press 'mode' again does it cycle to just furnace and/or just HP?
Gotta go campin!
Old 11-06-2018, 12:37 PM   #8
No it does not........when you get to the "heat mode" ...heat pump kicks on then few seconds later the furnace kicks on......thanks for your help though...
Old 11-07-2018, 02:53 AM   #9
rk06382's Avatar
I just turned off the A/C circuit breaker in the 120v circuit panel. The Heat Pump in the A/C can not come on without 120v. After that the 12v gas furnace worked just fine. I found out later, it could be done with the thermostat.
I did it that way because my Samlex EVO is on all the time, with shore power it is in bypass. I unplug from shore power and it switches to Inverter power in milliseconds. It is like having a UPS for my FR3. I alway have 120v power in my FR3. I'm thinking of setting the clock on the microwave.
Robert
2018 FR3 28DS | Boondock 90% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
furnace, pump
