Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 02-15-2018, 08:29 AM   #1
Furnace Break-in
This is trip 2 in my new Flagstaff 19FSB.
The morning is cold, and I turned on the furnace. The smoke detector went off.
Waited an hour tried again. Same thing.
Is it true I must "burn in" the furnace to avoid the smoke detector activation?
How long should I run it to burn in?
Chilly AM
PapiG is offline   Reply With Quote
Old 02-15-2018, 08:42 AM   #2
Yes, the oils used in the manufacturing and forming of the metals inside the furnace need to be burned off. Most report a 1/2 hour to an hour with the vents/windows/doors open does the job. I find on a new one if I crank the 'stat all the way up and let it run for 20 minutes to a half hour non-stop, it does the trick.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel•Goodyear Endurance Tires•2017 Ford F-Series SCREW 4x4•Factory Puck•B&W Companion•TST Tire Monitor w/Repeater•Sinemate 3500w Gen.
Days Camped: '17=38 '18=49 '19=58 '20=110 '21=116 '22=19
Old 02-15-2018, 08:49 AM   #3
Thank you. I'll run it and post how that worked.
furnace
