Originally Posted by Cworf
Did you ever get this fixed? I'm having the same issue.
While at the campground, I pulled the thermostat off the wall and jiggled the wires. The furnace shut off. I still don't know if that was a coincidence.
I took the RV in for repairs and maintenance. When I picked it up, they told me that all of the wiring looked good. They did not find any shorts. Then they began to explain to me how the system worked, that I needed to check both zones, etc., etc.
When the repairman stopped telling me what I already knew, I explained that the temperature had reached 97* in the trailer and was still going.
He advised that if it happened again, I pull the fuse for the A/C to stop it, and then said it could be a faulty thermostat.
I will likely bring it back to them for a new thermostat after our next winter-time trip.
