Free 7 Day Trial RV GPS App RV Trip Planner RV LIFE Campground Reviews RV Maintenance Free 7 Day Trial ×
Old 05-22-2017, 09:47 PM   #1
John Dorsey's Avatar
Furnace fan blowing when water heater on
So we wanted a fast recovery and turned the gas and electric on to the water heater. Now the furnace fan wants to blow even though the thermostat is off. It's not even full blast blowing but only the cold air return and bathroom.
2016 Brookstone 395RL
2013 Ram 3500 DRW
2001 Winnebago Brave
1998 Rockwood popup
John Dorsey is offline   Reply With Quote
Old 05-23-2017, 08:50 AM   #2
SeaDog's Avatar
Boy that is one I haven't heard of before. When you turned on the electric you used the switch at the water heater correct? Are you sure its the furnace fan it would blow at all vents if on. Let the forum know what you find and how you corrected it.
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-23-2017, 12:03 PM   #3
That's messed up!
I was thinking a bad ground, but I'm not sure if that would cause anything like that.
Have you pulled one of the fuses at a time to see if the furnace stops?
Gotta go campin!
Old 05-23-2017, 06:09 PM   #4
It is weird, I'm inclined to agree with Bama Rambler and a loose ground. But it was also the first time we have used gas to heat the water heater so my initial thought was because the heater is under the furnace so it tricked a sensor into thinking the furnace was on. But it didn't stop so I pulled the fuse. I'll add it to the long list of warranty issues.
2013 Ram 3500 DRW
1998 Rockwood popup
Old 05-23-2017, 06:25 PM   #5
Flybob's Avatar
Are you sure it it the furnace? The converter has an automatic fan that will turn on when 12V current draw is high.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-24-2017, 07:47 PM   #6
Evereddie's Avatar
Ding, ding, ding. I agree.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is offline   Reply With Quote
Old 05-24-2017, 08:18 PM   #7
There is a lot I don't know about this trailer. I wish the manuals included a wiring diagram. The vent in the bathroom was blowing cold air and I the furnace acted like the blower was on (I went outside and heard it). But the converter fan explains the fan I hear in my bunk room. I wish I really knew how the underbelly is heated. I thought it was the big vent that looks like a cold air return but now I think it's a converter fan running.
2013 Ram 3500 DRW
1998 Rockwood popup
Old 05-24-2017, 08:23 PM   #8
Flybob's Avatar
In many TT the heated underbelly is accomplished by one of the furnace ducts dumping into the underbelly. Not nearly as fancy as it sounds.
TST Tire Monitors
2 100W solar panels
Old 05-25-2017, 06:41 AM   #9
Are you sure it isn't the A/C fan blowing? Air coming from ceiling vent? If so, be sure thermostat is set to auto, not high or low.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is online now   Reply With Quote
Old 05-25-2017, 07:57 AM   #10
CedarCreek Woody it was definitely the floor vent. That 4 inch round vent and the bedroom vent are on the top of my must replace items. When the furnace is on all most all the air dumps out back there. Which further puzzled me because most of the air was coming out of the bathroom vent. Someday when I don't care about the warranty as much I'll definitely be dropping the belly to see what kind of mess is under there.
2013 Ram 3500 DRW
1998 Rockwood popup
Old 05-25-2017, 07:58 AM   #11
CedarCreek Woody I only wish my AC worked that well lol
2013 Ram 3500 DRW
1998 Rockwood popup
Old 05-25-2017, 09:04 AM   #12
Wolverine 1945's Avatar
Loose grounds can do some strange things,,, I once had a little Plymouth that when you turned the heater fan on,,, the speedometer would go to 0 ???
Wolverine 1945 is offline   Reply With Quote
Old 05-25-2017, 12:38 PM   #13
Ok, just wanted to be sure that we understood what you were saying. Unfortunately I'm no help either, that is certainly strange.
Andersen hitch
Old 06-30-2017, 09:29 PM   #14
Ron045's Avatar
Where is this converter typically located? I have a 23IKSS Hybrid. I hear a faint fan noise when plugged into my shore power that a do not hear when on battery only.
I thought it was my furnace too but everything related to it on the thermostat is off. If I turn off the breaker for the furnace, the fan noise also stops.
Thanks.
Ron
Ron & Family
2021-14 Nights, 2020-10 Nights, 2019-25 Nights, 2018-30 Nights, 2017-23 Nights
2017 Shamrock 23IKSS
2022 Ram 2500
Ron045 is offline   Reply With Quote
fan, furnace, heater, water, water heater
