Originally Posted by cavie
furnace works fine this spring. Today, not so much. today I get fan on. igniter spark but no burner. It tries to light 3 times then shuts down. Nothing visible to check or clean without removal. There is an inspection window on top but the bottom of the fridge is 3'' above. All I can see is full removal inspect and some sort of cleaning. this is a 2002. I'm guessing it's never been removed.
Any help?
When I had a similar problem it turned out to be burned up bug guts (I presume) in the burner tube that was disrupting the proper air/propane mixture. Blew it out with compressed air - a bunch of ash came out - and it fired right up.
Hope yours is as easy to fix.
EDIT: Sorry - mine was the hot water heater.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
