Old 01-22-2021, 11:34 AM   #1
Furnace
Hi, we have a 2017 Cedar Creek Hathaway Edition. The furnace quit working. It is a sealed unit. Has anyone else had this issue?
tmsrlamb is offline   Reply With Quote
Old 01-22-2021, 11:37 AM   #2
RV furnaces have some odd quirks. Sometimes they get dirt and dust in the orifices and switches. They are not like a regular res furnace. When I have problems like yours, I call a mobile RV repair man and they can fix it usually in a half hour for less than $50.
ppine is offline   Reply With Quote
Old 01-22-2021, 12:47 PM   #3
Furnace Issue
Originally Posted by tmsrlamb View Post
We have a 2017 Cedar Creek Hathaway Edition. The furnace quit. It is a sealed unit. Has anyone else had this problem?
Lots of folks have furnace issues.
You are going to need to supply us with additional information if you want help.
Do you have 12 volts? (the furnace runs on 12v)
Are you plugged into shore power or running off battery?
Do you have sufficient propane? (the furnace uses propane)
Had your furnace worked previously or is this the first you've tried it?
Do the stove burners light?
Help us help you by giving us all the information you possibility can.
Days Camped: '18=51 '19=58 '20=110 '21=60
Old 01-22-2021, 01:28 PM   #4
Furnace
12 V, yes.
I had shore power and did not work.
Propane, yes.
Furnace previously worked. This first time it didnít.
Stove burners do light.
Anything else?
Old 01-22-2021, 01:36 PM   #5
Boss Ox & Drovergirl
oxcamper's Avatar
Do you hear the ignitor clicking when it's trying to start?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2011 2500HD Silverado
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 01-22-2021, 01:59 PM   #6
Did the furnace come on and blow air for a bit when you 1st turned it on? This is a process it must accomplish (and prove out to the control board) before it will attempt to light.
Have you checked the furnace's 12v fuse?
Old 01-22-2021, 04:24 PM   #7
Furnace
Yes. Checked everything. Fuse is good. No, the heater did not come on.
furnace
