Originally Posted by KnP
Those things are pricey !!
They are. Here's one for "only" $500.
But keep in mind, two golf cart, CG2, 6v batteries will cost about $200 and give you about 115 usable Amps of its 230Ah. And then you have to keep up on the water levels, and make sure you don't shorten their life by not taking care of them.
The lithium is maintenance free, and you don't/can't shorten their life by running them down.
And if you sell your RV, take them out, drop in a new lead acid battery and put it/them in your next RV.
By the way, if it's so cold lithium won't charge unless you heat the battery, you're camping in the wrong place. Pull up stakes and move on... LOL
https://www.amazon.com/gp/aw/d/B084D...36KWp13NParams
