Old 10-07-2023, 12:50 PM   #1
Furrion camera monitor voltage?
Does anyone know if the power output on the Furrion camera 7" monitor is 12V? It plugs into a 12V accessory port but I don't know if there's a transformer in the plug that converts it up or down.
Yes, I can measure it but neither the cord nor my VOM is available where I am. I'm only asking if someone has already done that.
My intent is to purchase a replacement power cord on Amazon to hard-wire it to a power source in the ceiling console of my F150. If it's 12V, it's a direct connect. I'll just cut off the end, add an inline fuse and tap into something. If not, I have to figure out how to incorporate the voltage adapter.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, 57 YTD 8/18, EOY est., 90+
chriscowles is online now   Reply With Quote
Old 10-07-2023, 12:55 PM   #2
My internet search for "Furrion Camera Voltage" came up with specs for several models. All of them were 12volts.
Larry
Larry-NC is offline   Reply With Quote
Old 10-07-2023, 05:12 PM   #3
The back of my Furrion monitor.
Uses either 12v OR 24v input.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 10-09-2023, 01:00 PM   #4
Thanks, gentlemen. That makes my project easier.
Old 10-09-2023, 01:44 PM   #5
Rhumblefish's Avatar
12v. You're in good shape to cut and splice.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is offline   Reply With Quote
camera, furrion, monitor, voltage
