Originally Posted by Stevemal
Mine has a fan, a gawd awful loud fan! When set at one notch below all the way up it will shut off at 35 deg., but doesn't come back on until 43 -47 deg. and then runs for over 30-45 minutes with the inside temp of the trailer at 72 deg. I suspect a battery upgrade in the future. Haven't dry camped yet, will be the beginning of August.
Update- So I checked the fridge tonight after work and turns out there is a fan in there, behind the vent all the way towards the back. There was a strip of plastic that lodged itself in the fan, preventing it from spinning. I would've never known this since I've never heard any fan spinning, so I'm assuming it was some packing debris that was left behind from when the trailer was built.
With the vent removed I could barley get my arm in there far enough to pull out the plastic. After removing it I turned on the fridge and the fan spun but was making a loud noise. Turns out there was still some plastic strip wrapped around the fan shaft, so I had to pull out the fridge to get the rest of it out via removable back panel. Also pulled out some pieces of styrofoam, probably more packing material from manufacturing.
So you might want to check that fan and see if there's something stuck, possibly making the fan louder.
