Old 04-27-2024, 05:07 PM   #1
Furrion Radio External Speakers
We have a 2020 Grey Wolf 22rr and have owned it since new. A few months ago the external speakers quit working. I’ve pulled the radio and looked for loose wires, etc., but didn’t see anything that stood out. I have not used a voltmeter to test anything yet. Everything else on the radio works. Any ideas on what might be the issue? Thanks
Grey Wolf 22rr is offline   Reply With Quote
Old 04-27-2024, 05:13 PM   #2
Silly question
Silly question: Often these radios have selector switches for Inside, Outside, or Both. Might want to check that someone hasn't changed the switch setting while you weren't looking.
Not meaning to belittle you, but that's just the kind of thing a toddler might do.
Larry
Larry-NC is offline   Reply With Quote
Old 04-27-2024, 09:03 PM   #3
Ours has a Driven radio, it is marked Zone 1 and Zone 2 for inside and outside speakers.
One issue is every time the 12v power is turned off I loose the program and it defaults to the outside speakers. DR
dangerranger is offline   Reply With Quote
Old 04-28-2024, 07:46 AM   #4
Maybe test the output by connecting the zone 1 wires to the zone 2 wires and see if the problem follows the change. This would tell you if it is a problem with the speakers or the head unit. If it’s the unit go buy a decent car stereo.
MGD1961 is offline   Reply With Quote
Old 04-28-2024, 07:49 AM   #5
Thanks to both of you
Unfortunately I’ve tried multiple times over the past months the different speaker settings and still no outside speakers. And our grandkids aren’t tall enough yet to reach the radio. 😀
I’ll dig out the radio manual and see if it says anything about resetting the radio if the power is interrupted. I do shut off the battery feed when Gracie is in storage. Gracie is the toy hauler, not my wife…..
Old 04-28-2024, 07:51 AM   #6
MGD1961
Thanks for the advice, never thought of that approach.
furrion, radio
