Welcome to the forum. You should find a wealth of information from both new and very experienced owners.
There are two electrical systems in your RV. A 12VDC and a 120VAC system. Lights, water pump, furnace, DVD/Radio and controls for furnace, and possibly other items are 12VDC. The tv, A/C, microwave, one mode of operation of the fridge and WH are 120VAC. The 12VDC items are protected by fuses. The 120VAC items are protected by circuit breakers. Both protective devices are located in a panel that should look like the photo. If an AC item is not operating check the breakers. If a DC item is not working check the fuses.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
