The gas detector in my 2015 R-Pod178 has gone off a few times in the middle of the night. When resetting it keeps going off. I once took it to a dealer, had him check for leaks. After doing a gas pressure test they said it was probably wind blowing fumes into the trailer. The last time it went off I cut the wires and removed it. Looking for suggestions.
chances are it is a LP gas /CO detector. Dust and humidity will set them off. Did you have heat on when it went off in the middle of the night?
Check the date on the label on the back. The detectors are usually only good for 5 yrs. Manufactures buy them in volume for discounts so yours may have been on a shelf for a year before it was put in your unit. Good chance the detector is failing due to age.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Dust and humidity will set off smoke detectors but should not affect flammable gas/CO detectors. If your propane system is not leaking it could be a CO problem instead (very dangerous). Replace your detector with a new unit. Or, to test the theory, buy a cheap battery powered CO detector and place it where the "defective" unit was. If the new detector goes off you have a dangerous problem that needs to be addressed. Don't sleep in the unit without at least a CO detector.
