Geopro FBS19 TV questions
I can’t get our TV to find any over the air channels, or cable channels.
The coax connector on the TV has a purple cable that goes into the back panel.
There is a coax connection without a cable on the plate that the power connection comes from. This plate has a switch that toggles a green light on and off.
There is another coax connection without a cable that says satellite connection from receiver.
The dealer told me that when the green light is off the TV should be expecting a cable signal and when the green light is on the TV should be expecting an over the air signal.
The TV can’t find any channels when I turn the green light off and search for cable channels, and it can’t find any channels with the green light on and I search for air channels.
None of the documents that we received from the dealer explain how to find channels on the TV,
If someone can explain how this should work, I will really appreciate it.
Geo Pro 19FBS
Jeep Grand Cherokee Trailhawk
