Old 10-23-2021, 09:47 AM   #1
GFCI not resetting
I have a 2016 Rockwood 2703WS. I went to plug a laptop into an outlet and the power went off. Only have 12v. I replaced the GFCI but it seems as if there is no power being to the outlet. Is there another reset or GFCI in the loop that I don't know about?
Any suggestions welcome.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
Old 10-23-2021, 09:58 AM   #2
Jim34RL's Avatar
I do not about you trailer, but on my Cedar Creek when this happen to me. I found out I needed 120V/50 AMP circuit for the GFCI to be able to reset it. I tried my home outlet but this is only 120V/20AMP outlet in the garage. This is enough to power most items in the trailer except the AC. I had to reset the GFCI at the first camp ground where I could connect to 120V/50AMP circuit.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 10-23-2021, 09:58 AM   #3
D W
D W's Avatar
The GFCI will not reset without power. Suggest you look for a tripped breaker in your service panel or shore power source.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 10-23-2021, 10:06 AM   #4
Ok. I tested the GFCI outlet and I have 120v at the back of the outlet but it is not resetting.
2016 F250 SD 6.2L
Old 10-23-2021, 10:23 AM   #5
Seems odd plugging in a laptop would trip a GFI.
2021 Cedar Creek Cottage 40CRS
Victron MultiPlus-II 12/3000/120-50 Solar installation
SacRV is online now   Reply With Quote
Old 10-23-2021, 11:36 AM   #6
Jim34RL's Avatar
What is the Amperage of your circuit suppling the trailer?
Like I said before mine would not reset on 120v/20amp circuit. The GFCI needed to be on a 120V/50AMP circuit to reset.
Jim W.
Old 10-23-2021, 11:53 AM   #7
fonzie's Avatar
Did you wired it properly?
Fonzie
Old 10-23-2021, 11:54 AM   #8
D W
D W's Avatar
Do you have the "LINE" and "LOAD" wires attached correctly? LINE is the feed from your service panel, LOAD is the circuit it feeds.
2016 Salem 27RKSS
Old 10-23-2021, 12:16 PM   #9
I have double checked the outlet wiring and it is correct. I checked the wiring at the outlet where I tried to plug in and it is good. I put a new converter in. No joy. There has to be a reset somewhere that I don't know about besides the gfci in the bathroom.
Marty
2016 F250 SD 6.2L
Old 10-23-2021, 12:27 PM   #10
D W
D W's Avatar
Marty
In Post#4 you stated you had 120V at the back of the GFCI. Do you have any voltage at front of the GFCI? If not, you have a defective GFCI. Is the green LED illuminated on the front of the GFCI? The GFCI is fed directly from your service panel. The only re-settable device between power and the GFCI is a circuit breaker in your service panel.
2016 Salem 27RKSS
Old 10-23-2021, 12:34 PM   #11
Yes. Power to the back. None coming out.
It is a new gfci tpday but it is 20a. Should it be 15a?
2016 F250 SD 6.2L
Old 10-23-2021, 12:45 PM   #12
If you have power to the gfci disconnect the load wires it should reset if it does then you have a problem past the gfci that is causing it to trip a ground fault . if it still does not reset then it's a bad gfci . you do not need 50 amp service for the gfci
MR.M is offline   Reply With Quote
Old 10-23-2021, 12:48 PM   #13
D W
D W's Avatar
Considering that your wiring is most likely 14 AWG and rated for only 15 amps, a 15A GFCI would be the right choice. Your circuit breaker is only rated for 15A, so a 20A GFCI is unnecessary. Remember, amps is the amount of current flow according to demand on the circuit, and not to be confused with potential, i.e. 120V. The GFCI is not a circuit breaker with respect to load. It merely detects imbalances in incoming and outgoing current, and ground faults. Anyway, your GFCI appears to be defective.
2016 Salem 27RKSS
Old 10-23-2021, 01:02 PM   #14
Perfect. Thanks.
Marty
2016 F250 SD 6.2L
Old 10-23-2021, 04:38 PM   #15
So. I have replaced the gfci with a 15a gfci. I still have 120 on the hot side and zero on the load side. I give up. We will leave tomorrow and call an electrician friend of mind to figure it out. Thanks to all of you for your help.
Marty
2016 F250 SD 6.2L
Old 10-23-2021, 05:54 PM   #16
How are you connected to shore?
Old 10-23-2021, 07:19 PM   #17
A 30a cable though a surge protector.
Marty
2016 F250 SD 6.2L
Old 10-23-2021, 10:35 PM   #18
Did you check to see if it would reset with the "Load" wires disconnected? If it will then as mentioned in an earlier post, you have a ground fault in the load wiring or appliance down stream.
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is offline   Reply With Quote
Old 10-24-2021, 09:09 AM   #19
Is the outlet your shore power is connect to protected by a GFCI also? If it is they sometimes cause problems because 2 GFCI’s in a row often do not work well.
2021 Coachmen Freedom Express 246RKS
2020 Ford Ranger
DougW is offline   Reply With Quote
Old 10-24-2021, 09:33 AM   #20
PopFla's Avatar
Exclamation
If you haven't already, check any outside outlets for moisture or corrosion. On one of my previous rigs, I had a GFCI that wouldn't reset. Rainwater got past the cheap gasket and caused a fault. I dried out the box, replaced the outlet, replaced the gasket and caulked around the box. Never had another GFCI trip.
2018 Georgetown XL 377TS
2020 Jeep Gladiator "Toad"
FROG - FL-0145-951
Loving Life in "God's Waiting Room"
PopFla is offline   Reply With Quote
