Old 10-07-2018, 04:30 PM   #1
GFI light on tank monitor
Our 251 RKS has a tank monitor panel with water heater (gas) and water pump switches in the bathroom. Between the two switches is a GFI light. When the water heater (gas) switch is turned on the GFI light will burn for a short period. I have not seen anything negative happening. I have ignored the situation. Need I take this seriously?
andy10 is offline   Reply With Quote
Old 10-07-2018, 04:44 PM   #2
Mr. Dan's Avatar
GFI or DSI?
Later is Direct Spark Ignition
Old 10-07-2018, 04:54 PM   #3
bubbles's Avatar
andy10, your system is working correctly. The GFI light is the DSI light for the water heater. Evidently you didn't get a manual or you have not read it. Google for RV water heater manual and all will be explained.
Old 10-07-2018, 07:51 PM   #4
thanks
I may have misread it. The test on the panel I have found difficult to read as it does not seem to work with the background colors/design. I must have missed it in the manual I will try again.
Old 10-07-2018, 08:13 PM   #5
If it's anything like our water heater light, the light will light for a few seconds while the water heater is turning on. It will go out when the water heater lights. If it stays on, there is something wrong and the heater is malfunctioning or we forgot to turn on the propane.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 10-07-2018, 08:43 PM   #6
Kanadian Kamper
kenandterry's Avatar
Exactly what Reverse said ^^^^
Ken and Terry
kenandterry is offline   Reply With Quote
light, tank
