I never understood all this worry about hanging a TV in a RV. Simply decide where it needs to go to look proper, and attach the mount. Lay out the hole patter, drill a small pilot hole and see if there is backing, by using an awl or similar ice pick. If there is additional wood there, you're golden and just use the proper screws. If it is only paneling, use a properly installed hollow wall anchor, and you're done.
Instead of the cheap little ones for sheet rock (with a fine thread #8 screw), go to any NAPA or auto parts store (Harbor Freight) and get a set of jack nuts, with 1/4"-20 screws. Costs a couple dollars. Plenty of YouTube videos on proper installation and use.
2019 Sunseeker 3010DS
160w/9A roof top SOLAR
Playmaker DISH w/ Wally
