Old 10-26-2019, 07:04 AM   #1
Heat pump temp good to?
I have a 2009 sunseeker 3100ss and wondering what temp it's good to... Not on average or what some are, but what this model is good down to pls... thx!
SunseekerDave is offline   Reply With Quote
Old 10-26-2019, 07:22 AM   #2
There is no magic number.
When the logic board in most thermostats determine the heat pump can't keep up (system runs too long) or a big offset needs satisfied (moving the thermostat from say 60 to 80) then it will typically switch to furnace.
Also, outside humidity has a lot to do with how much heat can pe pulled from a certain ambient temperature. The conditions of getting heat from 40 isn't always the same.
Days Camped: '17=30 '18=51 '19=58 '20=51
Old 10-26-2019, 08:05 AM   #3
bubbles's Avatar
Additionally, the manufacturer/model number of your heat pump is what may provide the info you seek; not the RV model number (installed units can change throughout production years).
pump
