you would be correct in that interpretation. "G" is always fan, Y is always cooling, W is always heat. HVAC Industry standards
There's very little difference between high and low on the AC, you can hardly hear or feel the difference. The furnace fan is controlled by the furnace. Make sure the fan setting is set to "auto" or the AC fan will run whenever the furnace is on.
