You have a converter, not an inverter. Since you have AC power, it's not the main breaker. One of the other breakers, feeds the converter. Also the two bigger fuses feed all the DC stuff, so check them. Otherwise sounds like your converter went out. Make sure your battery leads aren't touching anything, since you don't have a battery. Good idea to tape them up so they can't touch. Can blow a fuse, even when not plugged in.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
