01-15-2024, 11:44 PM
Help! Oven randomly stopped working…
I used my oven this morning and everything was working fine. All of a sudden this afternoon nothing. The burners aren’t working and the pilot won’t light to the oven. I did notice when I pulled the top off that there was some water from a pot over boiling but I dried it well and nothing. It is cold out so not sure if that’s playing a part into it as well? But I’m not smelling any propane and it’s like it’s completely off. Been YouTubing all day and I just don’t even know where to start. Please help!! Also, Everything else is working with the propane.
01-16-2024, 07:55 AM
Old guy having fun
Good morning, Brittany. Welcome to the site. I am sorry you are having trouble with your stove.
Can you let us know what trailer you have (make, model and year) and, if possible, manufacturer and model number of your stove? That would help us help you.
Dave / Believer45
2013 Forest River Windjammer 3008W
2011 Ram 2500 crew cab short bed diesel 6 speed auto 3.73 gears RWD
01-16-2024, 08:29 AM
try your furnace or hot water do they work?
make sure gas tanks are full
Tarpon Springs FL
2022 Salem 24RLXL
01-16-2024, 08:34 AM
Old guy having fun
That was my first thought too. According to OP everything else propane is working.
Welcome to the forum, I see it is your 1st post!
The first place to start troubleshooting is with the basics.
What do you mean everything else with the propane is working?
That said, do you have propane?
Do you have one tank or two?
Do you have an auto-switchover regulator? (do you know how it works?)
Do any of the other LP fired appliances work? (water heater, furnace, possibly refrigerator)
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=101
01-16-2024, 08:41 AM
My furnace, hot water, and fridge are working perfect with my propane tank. I have just one. I have a Forest River 2018 Crusader And the stove is a wedgewood Vision and the model number is 1735 BSPS. Thank you for the help I’m an rv newbie!
01-16-2024, 08:44 AM
Is the oven in a slide out?
Sometimes supply hoses will kink from moving the slide in/out.
01-16-2024, 08:48 AM
No it is not and it worked yesterday morning and then randomly just stopped in the afternoon.
01-16-2024, 09:04 AM
Then I suggest you'll need to do some testing as to whether you have LP at the stove/oven. I have seen LP supply lines and supply manifolds have some gooey stuff inside that has blocked the line.
01-16-2024, 11:05 AM
I would suspect the regulator in the stove. I say this because the burners are also not working. As 5picker said, it could also be the manifold. That and the regulator are the only things common to the burners and the oven.
If it was me, I would make sure there are no ignition sources and then, loosen the connection to the regulator and listen for gas escaping. If yes, quickly tighten the connection. There’s a good chance the regulator is bad. If no, there is a possibility of a plugged of kinked hose.
So, is all of this beyond your mechanical abilities?
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
01-19-2024, 06:36 PM
Thank you for the help! It was the regulator. We have a warranty so we had someone come out and he verified that’s what it was.
01-19-2024, 06:40 PM
Glad they got you fixed and thanks for coming back to tell us what the fix was. Many people never come back and we are all scratching our heads and wondering! LOL!
01-25-2024, 09:30 PM
I have a suburban oven there is a regulator under the burners on left side.
01-25-2024, 10:11 PM
See post #11. It’s fixed.
