05-17-2017, 08:09 PM
HELP Stranded
Steps hit something when expanding. They stopped about 3/4 of the way out. They now do nothing. Key on and off several times, step switch on and off. Nothing. Lamp under steps usually lights up when steps are out. It is not on, so I assume that there is a fuse or CB tripped somewhere. I checked all fuses in the house and all good. I also checked all the fuses I could find in the wiring. The wiring diagrams are terrible and don't even show the steps.
Its a 2015 FR3 25'. Cant move till we get this resolved. Any assistance? Where is fuse/cb? Where does it get it's power?
Jim and Katy
w/ Shelby and Sealy (Bernese Mountain Dog and a Nice Mut)
FR3
HAM CALLSIGN - AI4SR
EE, IBMer, Race Car Builder, now Retired.
05-17-2017, 08:31 PM
Update. The step lamp IS on with the house door open. It goes off when I shut the house door. So it is getting 12V to the assembly, but the motor doesn't work. Limit switch or motor bad?
Jim and Katy
FR3
05-17-2017, 08:34 PM
Are they just "stuck" against something still? Can you carefully, with a helper, open the door and try and help force them down?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
05-17-2017, 08:36 PM
Possibly a gear is broken if the steps opened up and hit something.
You could head to a lumber yard and see if they do you a favour and fabricate a set of wood steps till you get home and/ or get it fixed.
05-17-2017, 08:40 PM
Steps are out right now. (about 3/4 of the way) They hit something when going out and just stopped there. There is no obstruction now. All is clear, but steps are just sitting there and won't move in or out with the ignition key, or the step switch. The lamp does go on and off. The motor does NOT run. So I doubt gears are the problem.
Jim and Katy
FR3
05-17-2017, 09:13 PM
Boss Ox & Drovergirl
Can one person activate the switch while another physically tries to pull them out?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
05-17-2017, 10:19 PM
Fuse or circuit breaker?
2017 Puma 297RLSS
05-17-2017, 10:40 PM
Maybe this will get you back on the road:
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
05-18-2017, 09:47 AM
Bob, Thanks. That WOULD HAVE helped except the position my steps were in did not allow me to remove the operating link. So I had to take the full step assm down and remove the motor from the assm. Then disc. stuff. A pain...
I installed my own switch to raise and lower the steps. Something is wrong with the limit switch in the unit and I will have to fix later.
thanks
Jim and Katy
FR3
