Old 01-16-2019, 03:18 PM   #61
Originally Posted by spock123 View Post
The furnace is trying to light but the furnace doesn’t light, I can smell propane. Any thoughts
It’s a friends travel trailer. We changed the regulator. The range works fine. Also the hot water heater works on LP. We have tried banging on the furnace.
Guess what I fixed the furnace and have no idea what I did to get the furnace working. I did beat on top of the furnace and turned the range top on, all three burners.
My best guess was a stuck sail switch.
How old is the unit?
Had they run out of propane?
Days Camped: '17=30 '18=51 '19=58 '20=88
Old 01-16-2019, 03:24 PM   #62
The trailer is a three years old and the camper switched tanks. Then the furnace would not light back the next day
spock123 is offline   Reply With Quote
Old 01-16-2019, 03:29 PM   #63
It can sometimes take many lighting cycles to purge the air from some appliances. Maybe it just took that long. Lighting all three stove burners probably helped.
Old 01-16-2019, 03:38 PM   #64
Anyway Iím glad something worked
Old 01-16-2019, 04:58 PM   #65
Brother Les's Avatar
Anyway I’m glad something worked
You almost answered your own question. There was 'air in the lines'....
Everyone that has used a camper very much will know that when the 'propane' is shut off, air will creep into the lines. What 'we' then do when we want to get the Fridge ready to 'run on propane' when we drive down the road.... 'we' turn a burner or two on the stove to know when propane is to the fridge. Why?? because if no propane and the Fridge is trying to 'light', it will only spark to light for around 45 seconds and then shut off and show the 'light of death' on the fridge.... THEN 'we' turn on a stove burner and wait... and wait.... and then hold a lighter on the stove burner and watch the air in the lines blow the lighter flame around for a minute or two and then woooosh... sweet propane. Push fridge button and fridge lights after a couple of clicks...
Now, we can not stick our lighter down by the furnace burner and 'wait' and 'wait'... no, it must purge the air out at its' own pace. You said that it was 'trying' to light.... we also know that the 'fridge' tries to light and will not after awhile, same with furnace. Give it a few minutes and then try the furnace again... the furnace then comes on and the wife thinks 'I' fixed it and that I know what I am doing...(oh sorry, flash back from the last time we used the furnace....) Tell your friend the secret.... give it time to purge the air out....
Brother Les
Brother Les is online now   Reply With Quote
furnace
