Hi. You should find the WH bypass valves inside the camper where the WH is located. I have a Grey Wolf 23MK, and the bypass valves are under the driver side front closet. Reachable (barely) through the under bed storage (or crawling into the outside pass-through storage which I didn't want to do). If you turned the electric side of the WH on with no water, you'll need to replace the heating element. Gas side should still work though. Electric side is turned on by toggle switch on the WH, gas is inside on instrument panel.
Good luck.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
