First thing would be to determine if there is power to the fridge, however you probably need to pull it out to check.
Since you mention inverter I assume this is a 120V fridge.
Are you plugged into shore power? If so I would turn the fridge breaker off then back on. If it it not a dedicated breaker try them all.
If your not on shore power what is you battery voltage? At the inverter if possible.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
