Old 07-13-2020, 07:42 PM   #1
Hot water heater coachmen catalina 261BH
How often do you need to drain the hot water heater?I thought I was told everytime but now hearing otherwise. If its ok to not do everytime where does this fall into the order of breaking down camp bc I know you should turn Off the switch and purge it right? So at our site this weekend we disconnecting water then electric then connect to tow vehicle. Had to drive out to main road and do black/gray flush as it was not at site. Do you pull plug and drain hot water heater at site? At storage? Or as you are going down the road? There was more water than I expected but not a great deal. Just trying to learn when and where (and how often) this needs to be done.
Thanks.
TX First Timer is offline   Reply With Quote
Old 07-13-2020, 08:05 PM   #2
wmtire's Avatar
Thanks.
Welcome aboard, here are a couple of thread links that may help:
https://www.forestriverforums.com/fo...er-160263.html
https://www.forestriverforums.com/fo...an-124130.html
2011 Flagstaff 831 RLBSS
Old 07-13-2020, 08:18 PM   #3
Thanks WM Tire, for the knowledge and info, humor, and spell check advise.
Old 07-14-2020, 07:14 PM   #4
Once a year for me.
NavyLCDR is offline   Reply With Quote
Old 07-15-2020, 03:59 PM   #5
Jack350's Avatar
Between use I will run the hot water in the outside shower to flush and change the water in the tank. Usually around two week intervals. This keeps the water from getting the sulfur smell and the camper ready to go.
2017 Open Range RES 347, 2022 F 450 4X4 LWB 6.7.
Hayes Autoformer, Moryde SRE 4000, Sailun Tires, Andersen Aluminum hitch.
Jack350 is offline   Reply With Quote
Old 07-15-2020, 06:10 PM   #6
It can also depend on the water. Well water with lots of minerals will react very badly with some heater tanks.
markb422 is offline   Reply With Quote
cat, catalina, heater, hot water, water, water heater
