Thanks for all the quick replies. I removed the mirror on the back, but that only revealed another board where I could see 6 screws coming through from the tv mount. On the outside of the trailer I found one of the common v-shaped lift-off mount plates, so after failing to get a good look with my cell phone camera, I used a borescope to thoroughly examine the back of the tv for anything that would keep it locked in place. I could find anything, so I went back to lifting and wiggling until it finally came off. I'm guessing that it hasn't been moved in a long time and just settled real tightly into that mount.
After getting it freed, it now lifts off pretty easily.
It sure would have been nice if they just put an HDMI port in the upper cabinet as ejohnson1144 mentioned. If this were my trailer, I'd run hdmi extension cables to an accessible location so that nobody has to lift the tv just to plug in a device.
