Old 02-24-2024, 07:33 PM   #1
How to shut off everchill fridge
Just purchased a 2024 sabre 38dbl. It came with an everchill 12 volt french door fridge with 2 lower draws for the freezer. Model SRM-418CBG-E. Is it possible to shut this fridge off? I see no on/off button. From the instruction booklet there are only 5 modes of operation nothing about shutting it off.
lime4x4 is offline   Reply With Quote
Old 02-24-2024, 07:57 PM   #2
I press and hold the Set button for over 10 seconds to turn mine off.
Some have found that if you remove the battery or open the 12 v cuttoff switch and then return power that theirs comes back on. I have not had that issue. Good Luck DR
dangerranger is offline   Reply With Quote
everchill, fridge, how to
