with everybody's trouble shooting tips i believe that I have discovered the issue.
It was not with the HW tank it self. it was between the rv breaker and the plug that the HW plugs into.
could be a break in the wire or even the plug
I currently have a new wire and plug from the panel box as a temp for testing
so far has not blown the breaker
there is easy access to from the panel box to the HW tank, I should be able to run new wire to it with no problem.
I'm sure this will be easier then trying to trace the wire, and find a junction box buried somewhere in the underbelly.
next question is:
household 14/2 wire good enough or do i need outdoor rated wire?
and house hold plug good enough also?
Thanks all for the help
2017 Ford F150 XLT
2018 2504s Rockwood mini lite
