Old 10-17-2019, 09:31 PM   #1
I.D this T.V. antenna?? 2016 wildwood 261BHXL
Need help to I.D this antenna, did a scan on both t.v's with no channels found. Just purchased used and have no manuals so no ideal where to start troubleshooting for signal. My zip code is 35456 an i understand i am rual, still i should get one channel that is around 20 miles.
Name:	R.V. Antenna 1 .jpg
ID:	217510   Click image for larger version
Name:	R.V. Antenna 2 .jpg
skidrowe is offline   Reply With Quote
Old 10-18-2019, 02:43 PM   #2
Post
Found this after looking at the last few pages of the internet. Continu US CA-1500 omnidirectional antenna. After read more on this antenna, it would be safe to say "abandon all hope" for t.v signal. Now to push on to maybe a satellite. Not looking forward to replacing the antenna as of yet with the lack of experience of working near or on the r.v. roof.
Any suggestions would be great. example would-- be can you work while standing on the roof??
I weigh 270lbs what is the max load limit for the roof??
Old 10-18-2019, 02:45 PM   #3
Herk7769's Avatar
It looks like you could use a newer antenna.
When mine was new, a dealer tech that had to be pushing 300 climbed my ladder and walked all over it.
Just stay off the panel seams (if you have a 5th wheel styled roof made of panels). They will flex and the trim that covers that seam inside will get loose.
HAM CALLSIGN - KC3FFW
Old 10-18-2019, 02:47 PM   #4
My new Surveyor came with a Contin-US antenna, got no channels.
I tossed it in the trash and installed a "Batwing''. Bingo 30+ channels.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is online now   Reply With Quote
Old 10-18-2019, 02:55 PM   #5
cboss's Avatar
Any chance there is a data plate on the bottom side? I can't find that pic anywhere.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 780
cboss is offline   Reply With Quote
Old 10-18-2019, 03:32 PM   #6
D W
D W's Avatar
There is a data plate underneath, but you have to stand on your head to read it. All it says is CA1500FMW, continu.us.
I have one of these on my rig and it works like a charm. I can pull in channels 35 miles away, and that is a feat in itself here in Alaska. My neighbor has one of those King Jacks on his 5er and 15 miles out of Anchorage he gets pixilation. Go figure.
The CA1500FMW is now obsolete. It has been replaced by the CA1500W. My neighbor replaced his King Jack with one of these from Amazon:
https://www.amazon.com/Continu-us-Om...1430509&sr=8-3
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 10-18-2019, 03:53 PM   #7
Flybob's Avatar
Pretty much useless.
Be aware that the hole in the roof is just big enough for the coax to pass through so adding a rotatable antenna like King jack will require cutting a larger hole.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 10-18-2019, 03:58 PM   #8
This was the Contin-US I had
https://www.amazon.com/Omnidirection...NsaWNrPXRydWU=
Old 10-18-2019, 04:42 PM   #9
BigHomey's Avatar
Do you have a booster, and is it on?
AL
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 75th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
BigHomey is offline   Reply With Quote
Old 10-18-2019, 08:14 PM   #10
Yes, and it has been turned on for each scan. I think this antenna is a "no go" and would like to replace, Big draw back is i am not familiar with working on R.V roof.
Old 10-18-2019, 10:40 PM   #11
Mch5jdm's Avatar
In your first picture it looks like an old park bench. Beyond that no clue.
Letís go camping!
Mch5jdm is offline   Reply With Quote
antenna, wildwood
