Old 04-07-2022, 01:39 PM   #1
Installation of Coleman Mach in bedroom
I have a 2021 Rockwood UltraLite with a 15,000 BTU Coleman Mach 15 in the living room. I was told that the bedroom is wired for the second ceiling air conditioner since I have a 50 amp service. I have chosen the Coleman Mach 3, 13,500 BTU signature series in black. Iím planning to use the ceiling assembly model number 9430D715 with Bluetooth capability. I believe these two are compatible. But before I order these two pieces of air conditioning items, has anyone else installed these two items especially the Bluetooth ceiling assembly? Please advise any cautions. Thank you
LadyBea is offline   Reply With Quote
Old 04-07-2022, 02:50 PM   #2
Ok
Old 04-07-2022, 03:38 PM   #3
I have swapped out the regular ceiling panel for the bluetooth ceiling panel. There are parts that you will use from the bluetooth ceiling panel instead of the parts that come with the A/C unit - so make sure to check out what those parts are and use them right from the start so you don't end up having to swap them out.
Also, on some A/C units, the control box for the bluetooth ceiling panel gets mounted upside down. If it doesn't seem to fit onto the bolts to mount it, try flipping it over.
NavyLCDR is offline   Reply With Quote
bed, bedroom, coleman, roo
