Old 11-23-2021, 09:23 AM   #1
Inverter
I am needing to replace the inverter on my Cedarcreek. It is a 1000 watt and I was wondering if someone knows what is the best one available and has good results
ccjdcamaro is offline   Reply With Quote
Old 11-23-2021, 02:18 PM   #2
I purchased a Renogy 2000 watt inverter for $299 and am extremely happy with it. Pure Sine Wave, low idle current, output can be hard wired if desired without having to resort to plugs, and it runs my microwave with ease
Just my experience..
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 11-23-2021, 02:47 PM   #3
rk06382's Avatar
I like Samlex America. I have used my Samlex EVO-3012 Inverter/Charger since July 2019.
Call and ask for pre-sales:
Samlex Headquarters
103-4268 Lozells Ave
Burnaby, BC V5A 0C6
Canada
Office Hours: 8:00am 4:30pm
TOLL FREE 800-561-5885
PHONE 604-525-3836
FAX 604-525-5221
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 11-23-2021, 09:43 PM   #4
Keep in mind that if you buy a larger (greater wattage) inverter you will likely need to replace the cables from it to the battery.
Mikec557 is offline   Reply With Quote
Old 11-25-2021, 02:29 AM   #5
Like TitanMike, I purchased a Renolgy 2000 watt Pure sine inverter. I am very pleased with it so far, and the microwave runs cool and quiet, just like it does on shore power. The ability to hard wire a plug is a very nice feature that I used to wire up a 30 amp RV plug. What does the OP intend to do with his inverter? I would recommend using an inverter bigger than the expected current. For example, my microwave uses about 1350 watts,so theoretically I could get by on a good 1500 watt inverter. I went bigger so that when the inverter is running, its closer to the middle of its output range. IMHO, it will run cooler and last longer that way. Jay
Old Rv 2016 Rockwood 2504s.
Old TV: 2014 Silverado 1500 double cab.
New RV 2020 Jayco 24RBS
New TV 2020 2500HD gas.
Jay2504 is offline   Reply With Quote
inverter
