Yea, I would replace the 2.6 volt battery as it is probably damaged. I would then get a red jumper and tie the + of each battery in parallel just like the -.
I would leave the rest of the wiring the same as each leg to the breakers have the heavy gauge wire needed.
Then both batteries will charge.
