Originally Posted by A1notary
Please help. I have an IRV 66 and I watch regular tv from the antenna plus I have a dish. My dish was breaking up and skipping really bad. I did all my dish trouble shooting. Got all new wire. Even bought a new dish. Finally when I unplugged the hdmi from the back of my tv (it runs into my wall and into the back of my iRV 66) and plugged a new hdmi wire in.... all cleared up. So I pulled the face off the stereo . Pulled the stereo out. Ran new hdmi cable and the damn sound will not come out of the stereo from the antenna tv. I ran the cable from my dish thru the back and into the rear hdmi 1 port and it works fine when I switch the sources as needed. But I plugged the hdmi from the tv to the Arch 1 (not sure if this was where it originally was.. I know.. stupid i didn’t look ) but I have tried every hdmi port and I can’t get the sound for the tv on the antenna back thru the stereo. I have tried the different ports on the tv and the difference ports on the back of the IRV 66. I have tried the old hdmi. Able and two new hdmi cables. Can someone please confirm which hdmi in the back of the irv66 the hdmi should go to that runs from the tv. Thx.
HDMI-ARC to HDMI-ARC, but, check me out here, I think that does it playing DVDs, but not the TV going the other direction.
I've had 2 TVs and 3 iRV66
Both of the TVs had RCA pin jacks connected to the iRV and the SRC had to be set to the TV audio selection to play the tv through the iRV. If you have something else besides the Toshiba (1st tv) or the Furrion(2nd tv) that doesn't have the RCA audio pins, lets say a mini headphone jack or OIS(optical), that is probably where you want to come out to the iRV- RCA pin jack or to the iRV- OIS input. Most TVs now dont have the RCA audio jacks, so you're stuck with headphone jack and necessary connector or OIC.
If you use a digital optical/ Toslink cable which works fine, you will scroll through the SRC options on the iRV66 to one labeled OIS/ xxx?. That's where the optical signal connects. Good Luck!
