Originally Posted by Jasdow77
So I pulled the plate cover off which is located on the front wall next to the TV. There is only a hole, no wires or anything. I’m confused as to why it claims to be pre wires?
The wire is there, but you will need to do some searching to find it. There should be a 110v plug next to the wifi blank plate. Remove that for easier access behind the wall. I removed the control panel closet, my bathroom light and vent fan and the overhead cable and power to my bedroom TV. I knew I had a wire for it because I spotted it coming through the roof from underneath through one of the holes from removing things from the ceiling. Once I knew I had a wire, now I had to find it at the King panel. I used a borescope camera to find mine. It was nestled up against a wall stud and there is no way I could have found it without the borescope camera.
Once I found the cable, I just plugged it into the King WiFi router I found at my local RV shop and it works ok. The King router is not user friendly so I would look for one of the other options mentioned. But first you have to find the cable.
Why FR didn't take the time to pull it through the hole in the wall baffles me.
