Old 06-18-2017, 08:39 PM   #1
modaholic's Avatar
LCI Remote stopped working
Wireless remote only clicks , will not function my Slide out and awning . Both will function with the switches on the main panel. I checked the fuses and wires. 2017 Salem Hemisphere 282rk. I am 2 months out of warranty. Any ideas that can help me ?
modaholic is offline   Reply With Quote
Old 06-18-2017, 08:58 PM   #2
Remote and board (where fuses are located) need to be reprogrammed / synchronized. There is a black momentary button on the circuit board. Push the remote button and momentary button at the same time. Hold both of them until all the lights on the remote start blinking. Release both at the same time. You will be ready to program the remote. Press and hold each function on the Remote menu button until the light stays green then move to the next function until all functions are set.
I had the same issue.I contacted FR. They walked me through this process.
Good luck!
Vernon Gay is offline   Reply With Quote
Old 06-18-2017, 09:42 PM   #3
modaholic's Avatar
Thank you . I will try this tomorrow
Old 06-19-2017, 10:49 AM   #4
modaholic's Avatar
Thanks again Vernon, PS my lights did not flash and I did not have to read-program my remote. I'm back up and running. Last week I called LCI Tech support and he told me to check the fuse and make sure that the wires were tight, and if that didn't work I would have to replace my receiver, $450.00. You save me a lot $$$$
Old 06-19-2017, 04:32 PM   #5
Are you aware the fuses for the remote are on their own panel, NOT on the converter with the other fuses? You will have to search for it. Mine is under galley sink, others are in bed or bath. It looks like this:
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 06-19-2017, 08:49 PM   #6
modaholic's Avatar
Yes that's the one .as I just posted Vernon helped me and I got it . He saved me $450.00 thanks
remote
