Old 06-15-2024, 10:40 AM   #1
LGC
Leveling an Air Conditioner on Sloped Roof
I am considering upgrading my a/c and am concerned about efficiency on the sloped roof of my 5er. Where the a/c sits it is sloped about 10 degrees. Most manufacturers say up to 15 degrees is okay. However, I have seen 5 degrees recommended. It makes sense that the more level the better the compressor will function.
So, should I level and if so how? I figure that to compensate for the 10 degree slope would require I raise the rear of the a/c about 2 inches and I have not found a product or information that would accomplish this.
Any thoughts?
2013 Rockwood Signature Ultra lite 8289ws 5er
31', triple slide
2022 Ford F250 SD with 7.3 gas
LGC is offline   Reply With Quote
Old 06-15-2024, 10:55 AM   #2
Any thoughts?
If the ac installation guide line say 15 degrees take yes for an answer and donít over think it. The compressor wonít care. 15degrees is a common standard and will make no difference in efficiency. The compressor pumps the refrigerant in a gas form so the angle doesnít matter
MGD1961 is offline   Reply With Quote
Old 06-15-2024, 03:40 PM   #3
I believe it has more to do with the oil migrating back to the compressor.
2017 Wolfpack 315 Pack 12 5th wheel Toy Hauler
2013 F250 6.7 Diesel Dually 4x4
Odyknuck is offline   Reply With Quote
Old 06-15-2024, 08:59 PM   #4
I agree that +/-15 degrees will make little to no difference. As to the oil, it is much heavier than gas and will remain in the compressor sink thus keeping it lubricated.
Don't overthink the project. After all, the old one, to be upgraded, worked for how many years?
Bob
Bob K4TAX is offline   Reply With Quote
Old 06-15-2024, 09:48 PM   #5
We installed an additional ac unit in the bedroom of our 315 pack 12 on the front slope. At this moment I don't remember the manufacture however installation instructions stated max tilt of 5 degrees. I thought that was odd and as I already had the unit I ignored it. The unit seems to work ok.
air conditioner, leveling, roo, roof
