07-18-2018, 02:13 PM
LG Refrigerator while traveling
We are pulling out this weekend for our first long trip. I've read everything I can find on keeping the refrigerator cold and they all talk about switching the fridge to auto so it will jump to propane while hauling. My Sierra came with an LG fridge and for the life of me I can not find a switch for Auto, Electric or Propane. Does anyone know if the LG is equipped with this option or is it just the Dometic fridges?
07-18-2018, 02:18 PM
LG is just like your Home Refer! No Gas! Youroo!!
07-18-2018, 02:19 PM
If it is a residential fridge then no, 120 volts only. RV fridges have the propane option.
DYNAMAX 2016 FORCE HD
07-18-2018, 02:20 PM
Uhhh. Will it run on DC power while towing?
07-18-2018, 02:22 PM
Only if you have a Inverter! Youroo!!
07-18-2018, 05:47 PM
Your dealer should be ashamed for not going over this with you, during the PDI/walkthrough.
A residential fridge will only work on 120v AC from shore power or from an INverter connected to the batteries.
You need a minimum of two deep cycle batteries, preferably 6v golf cart batteries.
07-18-2018, 07:36 PM
I have four six volt Trojans plus a 1,000 watt inverter, refrigerator will work for four days without being hooked up to 120 volts. While riding on the road the vehicle alternator keeps the battery charged some
07-18-2018, 09:11 PM
You will be fine. Mine can run for several days on just the battery. Just make sure it is cold before you head out.
07-18-2018, 09:21 PM
Your residential (no propane) refrigerator will run for several days on just battery? I didn't know they would do that.
07-18-2018, 09:23 PM
i would strongly suggest that you test the refrigerator before you leave. by this i mean turn your inverter on and make sure the refrigerator is running without shore power connected or a generator running. this will prove to yourself that you know how to run the refrigerator using just the batteries.
also make sure your batteries are fully charged before you leave. if you can accomplish this the issue will be how long your batteries can run the refrigerator before they get discharged. if you can run the refrigerator on shore power in order to cool it down before you leave your batteries will last longer than if they have to accomplish the cool down while traveling. but plan on hooking up shore power (or generator) as soon as you arrive at your destination to let the refrigerator run off of shore power rather than the inverter and to also recharge the batteries. hope it all works!
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
07-19-2018, 07:10 AM
Well I took my Camper to my storage building and thought I turned everything off. One of my kids forgot something in the camper so I went back to get it about two and half days later and the fridge was still on and running. I couldn’t believe it.
07-19-2018, 07:16 AM
I have absolutely no experience with residential refrigerators other than what I read here. That’s why I asked. Looks like having the doors closed all that time really helped.
07-19-2018, 07:31 AM
Coach
You should have a switch in your control panel labeled Inverter. Kick that switch on when you disconnect from shore power and that should keep your fridge running. Make sure your batteries are fully charged. We usually cool the fridge on shore power before switching to battery.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
07-19-2018, 07:48 AM
This was on just 1 Battery? Not plugged in to Shore Power also? Youroo!!
07-19-2018, 08:15 AM
Residential '120v' fridges only 'run' as they need to, when the temp rises above the 'set' limit, not 24/7 as some would believe. Yes, it's possible that many folks can get way more time on their Inverter, than they think, with the fridge 'on'... but many have also been led down the 'I heard someone say...' road that somehow a residential 120v fridge 'sucks' battery power. I think that these 'terms' sometimes make folks fearful of the 'residential' fridge option, but it's a lot overblown, in my opinion.
Once you get used to how to make sure the batteries have charge, it's just like making sure that your propane tank has propane...it's a maintenance job we all have to get used to.
07-19-2018, 12:51 PM
Road Warrior
Having just traded a diesel pusher with a RV propane/AC frig to a 2018 XL 369DS with a residential LG frig I can unequivocally tell you its like night and day for the better with the residential LG. Its fantastic not to have to worry so much about being "level" or having to make sure it switches between propane and electric constantly, not to mention the maintenance issues with those dinosaurs. Having a worry free full sized frig with ice and filtered water in the door is wonderful and I would NEVER go back to the propane/elec version. It also helps that the 369DS comes standard with 4 house batteries...
Mike
2015 Fleetwood Expedition Pusher
Towing a VW Beetle Convertible
07-19-2018, 01:03 PM
My unit came with two batteries. I think most with residential fridges do. Well they should if they don’t. Not plugged into shore. I will never have anything but a residential fridge. I don’t boondock so that isn’t a factor to me.
07-19-2018, 01:19 PM
I think we have people posting each other rather than the OP, hence the confusion.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
07-19-2018, 01:38 PM
there is no such thing as a worry free fridge in a rv . get many calls on residential fridges going out even though they may be less then a yr old . Does LG know their fridges are running while going down a bumpy hwy then get calls for warranty work . also most techs do not work on residential fridges . so you'll have to find that appliance repair shop for warranty
07-19-2018, 01:55 PM
I have a Moffat residential fridge in my Heritage Glen 5ver. I have 2 x 12 volt batteries in the front hatch and an inverter screwed to the wall of my side hatch. My inverter has a square red on/off button.. then it is on the LED display will register home many volts it putting out and you will hear a fan. As the other posts have commented, I cool my fridge and charge the batteries while plugged in at the house before we leave. When towing, the truck charges the batteries and the inverter converts the battery power to 120v to power the fridge. In my trailer only the Fridge recepticle is connected to the inverter.. all the other recepticles are dead.
I have thought of, wiring another circuit from my bedroom to the inverternand adding a couple more batteries so it could power my CPAP mchine if there was a power failure. but for now I have a 3100 watt inverter generator that I can power the trailer from.
Jeff
