Old 10-09-2018, 05:50 PM   #1
Light not lit on outside power-outlet cover
The light on on this cover is not lit. There is power inside the trailer. Is there something I should check to make sure I'm getting the proper amperage? I checked the fuse box and nothing was tripped. I didn't check all the small fuses though. I've attached a pic. Any help would be greatly appreciated.
RooMan183 is offline   Reply With Quote
Old 10-09-2018, 05:59 PM   #2
Those lights go out all the time. Sometimes they will come back on and sometimes not. Just ignore it not telling you anything is wrong with your power.
2019.5 Rockwood 2509S
Toddupton is offline   Reply With Quote
Old 10-09-2018, 06:02 PM   #3
Mr. Dan's Avatar
You should appreciate this help. It is spot on.
Old 10-09-2018, 09:27 PM   #4
Mch5jdm's Avatar
I was wondering the same. Worked fine at first then suddenly stopped.
Let’s go camping!
Mch5jdm is offline   Reply With Quote
Old 10-09-2018, 09:33 PM   #5
There are lots of reports here of the light failing. Some had the port replaced under warranty only to have it fail again in a few months.
Someone took their's apart to try and fix it but didn't have much luck.
Mine failed at about 10 months.
Never worried about it.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 10-09-2018, 11:21 PM   #6
immecor's Avatar
Yeah mine went out as well after the first couple trips. Had it replaced under warranty. They put a new type on with a half moon light and has been good for about a year so far.
2017 RW 2304DS
2011 Expedition w/HD tow package
immecor is offline   Reply With Quote
Old 10-10-2018, 05:34 AM   #7
NH Maple Maker
russhd1997's Avatar
Mine does the same, sometimes it works and sometimes it doesn't. As long as you've got power inside the camper it's nothing to worry about. The lights at the plug stopped working on mine too.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is offline   Reply With Quote
Old 10-10-2018, 06:38 AM   #8
Our Factory power inlet receptacle is White and has no light, our Factory power cord is Yellow and has a LED light that" works" molded into the Screw Thread end! The newer power supply Receptacle box's and cords are Black and have LED indicator Light issue's,! Youroo! !
Old 10-10-2018, 06:58 AM   #9
jeff64's Avatar
Mine hasn't worked for a long time. No Biggie!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 10-10-2018, 07:41 AM   #10
Bill and Gail's Avatar
Mine went out after 1 year. Everything was working, so I just ignored it. It's still out for over a year now.
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
Bill and Gail is offline   Reply With Quote
Old 10-10-2018, 12:38 PM   #11
StlClay
I was really excited to see this and hoped that I would finally get the answer to the same problem that the writer had. Reluctantly I have the same problem and don’t pay any attention to it
2014 MiniLite with
Nissan Frontier
Stlcaly is offline   Reply With Quote
Old 10-10-2018, 12:48 PM   #12
mudman2's Avatar
X2
2019 microlite 25bds
2015 tundra
mudman2 is offline   Reply With Quote
Old 10-10-2018, 01:10 PM   #13
rlh1957's Avatar
These Furrion power led lights go out quite common. On one unit it went out, Furrion sent a replacement and said they go out. Replacement lasted about 3 months before going out. No problem. Just an indicator led. Not replaceable.
Got a new rig now... that Furrion indicator light lasted 6 months, then dark.
I dont even worry about it.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 10-10-2018, 01:28 PM   #14
NorSnrub's Avatar
My power cord had 2 they both failed. Still works just look inside an see if tv, microwave, or anything else comes on.
NorSnrub is offline   Reply With Quote
Old 10-10-2018, 02:59 PM   #15
Well it SHOULD work....
Our Rockwood 8311 is 3 months old and the light quit. Just because it happens to everyone, doesn't make it right. I'm planning on getting a replacement under warranty. If enough people complain maybe they'll start supplying a decent one. Just MHO.
Chazman is offline   Reply With Quote
Old 10-11-2018, 02:36 PM   #16
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by NorSnrub View Post
...just look inside an see if tv, microwave, or anything else comes on.
Or listen for the microwave to go "beep."
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 10-11-2018, 02:47 PM   #17
Ejs4029's Avatar
X2.....Mine quit working
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
Ejs4029 is offline   Reply With Quote
cover, light, power
