I have frig set on auto. Plugged into shore power at campground for last 6 hrs. Indicator lite flashes between 44 and LP . Never did this before. 85 degrees here in Fla. so hopefully it will cool down overnite and the just display numbers of degrees and stop flashing LP
Try turning off the fridge wait 5 seconds, then turn it back on. This happened to me, have propane turned off, when power went off, then came back on, mine did the same thing. Turning it off and on reset it.
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
The light flashing usually means it's trying to work on propane and went through the cycle with no flame. If you turn I off/on it may have bled the line and started working on propane. If you want it on electric check for no flame, circuit breakers, plug in back or fuse like Bama said.
Yepo, mine does the same if the LP is turned off and there's a power blip.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
