Old 07-04-2017, 12:57 PM   #1
Lost AC, microwave and outlets
Help please. It is hot. 2016 Sunseeker 2400S. Sudden loss of AC,micro and outlets. 30 amp we had only a small fan besides AC going.
I have checked all brakers We do have vent fans and lights.
Hope a
Someone knows this problem.
wmarion is offline   Reply With Quote
Old 07-04-2017, 01:07 PM   #2
B and B's Avatar
On electric or generator? Was your water heater on electric, that draws a lot. What about the fridge? Gas or electric? TV on or house batteries dead and convertor running to charge them.
Old 07-04-2017, 01:08 PM   #3
If you are in a RV Park.... Check the breaker at the pole... parks have a breaker and some have a GFI outlet that can be tripped.
Any adapters between the pole and RV? check for overheating/melting plugs.
N6ZCM is offline   Reply With Quote
Old 07-04-2017, 01:16 PM   #4
Electric yes fridge and water heater on. Don't think house batteries dead. Drove over 3 hours yesterday. RV 2016 just bought Nov. currently living in fulltime.
Old 07-04-2017, 01:47 PM   #5
Private campground just us here and simple one breaker switch. It is 50 amp using 30 amp adapter cord
Old 07-04-2017, 02:14 PM   #6
Some breakers will look like they are not tripped!
Try turning it off then back on.
Anyway to test and make sure there is power coming to the pole you are at?
Anyway to test the adapter make sure it didn't fry internally?
Since you are the only ones there, can your shore power cable reach your empty neighbors pole?
Old 07-04-2017, 02:28 PM   #7
Can't reach neighbor's pole. Will get tester to check if power there.
Thanks a lot.
Old 07-04-2017, 02:39 PM   #8
Originally Posted by wmarion View Post
Hope someone knows this problem.
You've lost 120 volt service. As someone suggested, look at the power connection from the RV park - reset the breaker and try it again.
Also, I think there's a master breaker for 120 volt in the RV. In my Solera there's a "Power Control Center" mounted near the floor below the stove. It's got a brown plastic cover, about 6 inches high by 15 inches wide. The right side of the cover comes off to provide access to breakers and fuses. The top-most breaker is the 30 amp master breaker.
Hope that helps
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 07-04-2017, 02:46 PM   #9
Thanks sounds good. I can get to main in office and check ther. Makes sense. I am on battery for the things that are working.
Thank you.
Old 07-04-2017, 03:18 PM   #10
Got power. Should have checked light on power cord. Breaker had flipped at office.
Thanks to everyone.
Old 07-04-2017, 04:53 PM   #11
SilverbackMel's Avatar
This is WHY we invest in ELECTRICAL MANAGEMENT PROTECTORS. You were LUCKY that there was no power pole short.
Protectors keep surges from burning up your equipment. GO AHEAD; ask; how would he know??
" bad experience, pre purchase of protector". Lost microwave and hot water heater in 5 seconds.
SilverbackMel is offline   Reply With Quote
Old 07-05-2017, 12:31 PM   #12
Wink
Well said!
I wasn't wearing my glasses and looked over at your info and thought it said "Dracula, GA" instead of Dacula, GA!
'17 XLT Screw | Oxford White | FX4 | 3.5L EB | 3.55 ELD | 302A |Chrome Pkg | Max Tow Pkg w/TBC | 36 Gal. Tank | Bak MX4 & BedRug | WeatherTech Deflectors, Floor Liners, & Mud Flaps | VA Navi | SYNC 3 Connect | Tailgate Step & Damper | Husky Liners | Goodyear Wrangler Fortitude HT 275/65R18
My wife and I are looking for our 1st travel trailer.
LynnGlaze13 is offline   Reply With Quote
