Mach Dual Zone, Zone 1 reads 41 deg
Hoping one of you smart guys have some experience that can help with this situation;
My configuration:
-Mach 15k and 13.5k AC with gas furnace
-No HP, no heat strip
-Dual zone thermostat
-Zone 1 temp sensor is local to the Tstat
-Zone 2 temp sensor is remote.
Notes:
-Zone 2 works as expected
-Green lights ON both upper control boards
-System has worked fine for the past 2.5yrs
-No new installations or changes to the trailer
-Thermostat/system responds normally to all commands except for symptoms below
-Fan controls operate as expected on both AC units
Problem: T-stat not reporting accurate temperature in zone 1. It displays 41deg (default minimum temp for the system per the manual). For a couple of days it slowly alternated between the accurate temp and 41deg then finally now just says 41deg constantly.
Symptoms:
1--When switched ON via T-stat, the furnace runs constantly. This is due to the zone 1 reported temp of only 41 deg. Setpoint 70deg, Actual temp in the room is 75deg in the test case.
2--When switched ON via T-stat, the zone 1 AC will not turn on. I believe this is due to the t-stat reporting a ambient temp of 41deg and set point is 78.
-----Note on symptom 2: for a couple days the Zone 1 temp slowly alternated between the actual room temp and 41 degrees. The zone 1 AC responded appropriately while set to AUTOCOOL and setpoint called for AC.
Steps I have taken to resolve the issue:
--Verified each connection from t-stat to Gas furnace. Found many loose connections in the basement and recrimped with new lugs. No change problem or symptoms noted above
--Verified each connection from t-stat to Zone 1 Upper control board. No loose wires.
--Replace T-stat: no change in problem or symptoms above. Verified programming and all systems operate with the exception of the symptoms noted.
I have been unable to find a troubleshooting guide from Mach on this system to take the next steps.
Equipment list involved here
Furnace: Atwood AFMD30121
Main AC unit: Coleman mach 15 model number 48254c869
Main Upper control unit 9430A751 Zone Control Kit (12vdc cool only)
2nd AC unit: Coleman Mach 3 Plus model 48203c969
2nd Upper control unit: TBD
Tstat: RVProducts(Airxcel) 9330A334
Thanks in advance.
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
