Originally Posted by 2queensinamini
Also in this process I learned that the higher the temperature knob setting in the freezer the less air would go into the fridge.
Yes. This is how all refrigerators work. The reason is that the refrigerator temperature is the most critical--needs to be maintained between about 34º and 38º. The freezer temperature can be anything from 30º to -25º or so, depending on how easy or hard you want the ice cream to dip.
The thermostat regulates the refrigerator temperature. The freezer temperature is set by a damper which divides the cool airflow between the two parts.
On a hot day, on a marginally-designed RV refrigerator, you could possibly divert so much air to the freezer part that the refrigerator part would never cool sufficiently, the thermostat would never be satisfied, and the unit would run continuously.
