Old 07-25-2024, 09:55 PM   #21
So, if I tape over some of the freezer vents, that would force the cold air into the. Refrigerator part? I have frost on the vents and around the door.
Crazy Dachshund Lady is offline   Reply With Quote
Old 07-26-2024, 06:28 AM   #22
New fridge
I have been having the same issue with my everchill (same fridge) . I got in touch with lippert who makes these . Ther tech. department was great to work with . I went through there test process and they determind the fridge was bad. The test consist of reading incoming voltage and current when first starting ,when the compressor comes on and after 2 hours . they also wanted temp at start and after 2 hours which in my case was 0 in freezer and 45 in fridge. Everything seems to work and I had settings at every possible combination , it would get to mid 50s while we had food on a trip. My motorhome was purchased in Oct. so they are sending me a fridge. I have not recieved it yet and I am hoping it works better than than the first .
JCKelley is offline   Reply With Quote
Old 08-08-2024, 10:43 AM   #23
Originally Posted by AlKemper View Post
You have to cut through the styrofoam too. Get a couple of these thermometers and check to see if it is fixed. They are on Prime Day sale today for $4 each or 2 for $7:
https://www.amazon.com/Refrigerator-...dp/B089NLQ7SF/
the styrofoam on the sides where the hole is cut has been cut out I ran a boar scope up from the bottom hole and there is a partition of styrofoam that runs across the chase way blocking the air its about 2 inches above the lowest side new hole cut in the air raceway and can't get to that to cut open
330DS is offline   Reply With Quote
refrigerator
