Old 08-09-2022, 04:10 PM   #1
Cato's Avatar
microwave
2014 2604ws Rockwood
need a new microwave
help
thank you
Cato is offline   Reply With Quote
Old 08-09-2022, 04:30 PM   #2
Rhumblefish's Avatar
Like this one?
Assuming it's truly dead, pull the old one, get dimensions and buy something matching. I've seen anecdotal evidence that greystone makes identical sizes (down to the mounting screw holes) to the Magic Chef branded ones, not sure about 2014, tho.
Are you sure it's dead? Internal fuse is a common problem with microwaves. Could be as simple as a $5 fix.
2022 Rockwood Roo 235S
2017 Audi Q7 3.0
WeighSafe hitch
Rhumblefish is offline   Reply With Quote
Old 08-09-2022, 04:37 PM   #3
Part-Time Campground Host
cboss's Avatar
Originally Posted by Rhumblefish View Post
Like this one?
It's not a fuse as the Microwave is 120 VAC. First check your circuit breakers on the power panel. Next check the GFIs, then then check the plug behind the micro.
Craig & Cath
Days camped since 2015(retirement): 1317
cboss is offline   Reply With Quote
Old 08-09-2022, 04:43 PM   #4
Cato's Avatar
thank you.
We have pulled it out.
(died peacefully)
Old 08-09-2022, 04:47 PM   #5
I'm not referring to 12v side of the trailer power system, cboss. 120 VAC microwaves contain internal fuses (line fuse and thermal fuse) ... hence the use of the term "internal." These are common failure points/replacement items.
I'm making the assumption the user has ruled out external issues (including power at the appliance) and is facing a dead microwave.
2017 Audi Q7 3.0
WeighSafe hitch
Old 08-09-2022, 05:45 PM   #6
Originally Posted by Cato View Post
thank you.
(died peacefully)
That's funny.
Get the make and model number of the microwave and do an internet search. Usually you'll find a replacement on Amazon.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
microwave
