Originally Posted by Kenzmad
Have figured out the over the air channels but how to get tv in a campground? Do they still do regular cable with coax? Streaming on the phone if signal is good is one option, but what if the reception is spotty or non existent? Im in Washington and half my state has good cell service and half does not. Im not new to the RV life, just new to having some creature comforts. Thanks folks!
You can usually get over the air channels in a campground.
To get cable in a campground, you're going to need a coax cable to attach to their service. It's usually located near the electrical hookup. You'll need to disconnect the antenna booster which is usually a button located somewhere near the tv. Then you'll need to scan for channels on your tv.
In mountainous areas, a campground with cable is usually the only option if you want to watch live tv. The other option is a satellite connection either permanent on the roof or portable, but that can be difficult if you've got a campsite covered by trees.
