Do not run your microwave when running your air conditioner when on a 20 amp or 30 amp supply. You might not trip the breaker on 30 amp service but that depends on if ANYTHING else is using power. Electric water heater? Uses about the same power as a small microwave. AC 13.5K or 15K BTU? 13.5 is borderline with other stuff, most 15s won't play together well. Low battery being charged can suck power, too. Coffee maker? Electric heater?
I shut off my air when microwaving. The battery is being charged, refrigerator running on AC, other things may be plugged in and pulling power. It's best to run large loads one at a time. If two large loads, shut off the smaller stuff that can add up.
Are you feeding a 50 amp wired TT? If so, TWO ACs?
2019 Cherokee Wolf Pup 16BHS flipped axle, 5K springs, 400AH LiFePO4, 3K inverter, 400 watts CIGS solar
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package, ITBC, Tow Mirrors, 3.55, SumoSprings, 7000# GVWR, 1990#CC
Husky Centerline TS WDH 400-600# spring bars
