04-19-2019, 12:00 PM
#21
Originally Posted by MR.M
if you're hooked up to shore power and 120 working then you need to look at converter it either went bad or a fuse blew for the converter or a 120 v breaker for the converter tripped , if it did trip it's for a reason . Also if since your powered up and lights are dim battery has been drawn down to almost dead . the problem will have to do with the converter
Took the panel off. No evidence or wires being shorted out.
04-19-2019, 12:03 PM
#22
Battery hookup
04-19-2019, 12:20 PM
#23
Spoke to the dealer. They’re fairly confident it’s a fried charge board. Not much they can do over the weekend. Sounds like I have to order the part, and head home for the weekend.
Thanks for your help everyone.
04-19-2019, 12:42 PM
#24
That's your deck mounted converter tucked under there . most likely went bad .
04-19-2019, 12:46 PM
#25
Put a portable battery charger on the battery for the weekend and enjoy the stay.
04-19-2019, 12:59 PM
#26
Battery hookup
There is a resettable inline fuse within 3' of the battery under the tongue. see it is working. you need a voltmeter.
04-19-2019, 01:31 PM
#27
X2
04-19-2019, 02:35 PM
#28
One more possibility
Only because it happened to me...
Underneath the trailer you will see a couple of the big ground cables (from battery and converter) connected directly to the trailer frame. Make sure those connections are tight and clean. My furnace misbehaved when those connections got dirty and rusty. They drew the apparent voltage way down.
Larry
04-19-2019, 03:01 PM
#29
Just as confused as you
Check the reverse polarity on the deck mounted converter. Have a friend who had a Cherokee with a deck mounted converter and the fuses were hard to get to.
Richard & Jill
04-19-2019, 06:41 PM
#30
Update! I took the panel off, and got to the deck mounted converter. Both 35A fuses were blown. Replaced them, and we’re up and running. Didn’t have to replace anything else. Furnace works. USB and all other outlets work. Lights work. The battery now shows as full on the indicator panel. All good! Thanks for all your advice. Camping for Easter is still on!
04-19-2019, 06:56 PM
#31
Kanadian Kamper
Excellent.
Anytime repairs don’t cost a fortune, is a major win.
Enjoy your camping adventure and stay warm.
Ken and Terry
04-19-2019, 08:04 PM
#32
Well, not quite
That's not quite what the panel is indicating. What the panel is indicating is that the converter is applying the full charge voltage to the battery and to the trailer appliances. If you were to have applied the voltage for just a few minutes and then removed the fuses again, the indicator would have shown the voltage drop.
Larry
